Idle mixture screw on 350 raptor?
Old Jun 19, 2007 | 03:52 PM
fastquad02blaster's Avatar
Default Idle mixture screw on 350 raptor?
I'm working on a buddies 350 raptor. It will not idle with the choke all the way off. With the choke on part of the way it idles fine but kindof fast. I was just wondering if there is an idle mixture screw somewhere. I can't find one. Could the intake boot be leaking or the diaphram in the top of the carb be leaking? Would they cause these symptoms.
Old Jun 19, 2007 | 04:54 PM
ATV_MAN's Avatar
On the bottom of the carb near the cyl side there is a screw, it's inside a small cylinder shape opening...this is your pilot mixture screw. The intake boot should be ok as long as you know it's on properly and tight. Also make sure the air filter is clean and the fuel is fresh. If these don't help you might have to dig into the carb and clean it.
Old Jun 19, 2007 | 05:30 PM
I think that it's the intake boot between the carb and the jug. When it's idling and it starts to get rough, I spray a little bit of starting fluid on the boot and it smooths out. That makes me think that the boot is leaking. Do you still think that the pilot jet could be plugged up?
Old Jun 19, 2007 | 05:50 PM
ATV_MAN's Avatar
That jet can be blocked knowing how small it is, the hole goes through to the intake tube above it. You can unscrew it all the way and spray some carb cleaner into it and see if it comes out the top. For the boot I would remove it and see if it is seated properly if someone has removed it previously before buying a new one, they have to be tight in order to keep the seal. If that doesn't help remove it and check for cracks around the rims and order a new one if necessary.
Old Jun 20, 2007 | 09:05 AM
I checked the boot for cracks and didn't see any. I'm not understanding why the starting fluid makes it smooth out if it's the carb acting up. I know that if I spray the starting fluid into the back of the carb(airbox side), it starts idling really rough.
Old Jun 20, 2007 | 09:27 AM
Williebee's Avatar
The carb need's to be removed and cleaned out and probally rebuilt , if nothing else a good cleang and adjustment ; if this help try adding some seafoam to your gas in the tank ! follow thre the instructions on the can for mixing , Seafoam is a fuel cleaner/stabilizer that will help keep the fuel system clean and combuston chamber clear of carbon deposits ! You can get the seafoam from O'Reilly Auto Parts for $5.99 + tax , you should get a good service and repair manual ; it will pay for itself on your first repair ! williebee
Firefighter400
Oct 8, 2022 06:38 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
brad wheeler
Jul 13, 2015 11:19 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
