Yamaha Blaster brake conversion
Old Jun 27, 2007 | 02:52 AM
Master_Blaster's Avatar
Default Yamaha Blaster brake conversion
I was wondering if I buy a 2004 rear Hydraulic brake setup if it just bolts on to an older model Blaster. I want to know before purchasing it and if it doesn't is there somekind of conversion kit to modify it for the newer stock hyrdaulic brakes???
Old Jun 27, 2007 | 06:46 PM
fastquad02blaster's Avatar
You might need the bracket for the caliper as well as all the rest of the setup. You will also need to make a bracket for the master cylinder. You will need the rear brake lever so you can hook it up to the master cylinder too.
Old Jun 30, 2007 | 12:55 PM
Blaster2oo2's Avatar
OOPs
Old Jun 30, 2007 | 02:19 PM
toddmh's Avatar
I'm baffled there is no way to report these jerks to a moderator to get banned..
Old Jun 30, 2007 | 02:32 PM
95wolv's Avatar
Don't listen to guys like Blaster2oo2, he's just grumpy because Mommy didn't feed him yet, updating the manual rear brake is a pretty straight forward project, you can even use some of the brackets and parts off a Warrior or Banshee to mount the rear brake caliper, the axle assemblies are pretty similar. To make a complete swap, you could even get parts like front spindles and calipers and a front brake lever set up from a Warrior or Banshee and get front disc brakes as well, and very cheaply if you find the parts in a salvage yard or ebay.
Toddmh, just look below your avatar, it says "report this to a moderator" on all the posts, just click on that, and you can send a message to a moderator, and don't worry, I already did it, but glad to see I'm not the only one not liking replies like that.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Oct 16, 2019 12:11 PM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
