1995 yamaha 350 warrior oil leak
ok so i just bought this warrior and the first thing i do is check the oil and its fine.then i keep riding and run out of gas.......so i get more gas and fill it up and then i notice after i filled up the tank..smoke is coming out of the exhaust and i think ok w/e and then about 30 mins later it dies on me and i try to start it up again and it dosent work....so i check the oil and it is about empty so i stop riding it and park it and then 30 mins later i check the oil and its empty....im just wondering what do i have to do make it stop leaking so i can get back to riding?
You're probably not leaking oil, you're probably burning oil in your engine and thats why your exhaust is smoking. If this is the case, you need to rebuild the top end. At least get some new piston rings or you could get a new bigger piston and rings and bore your cylinder 20 over. Being low in oil will not make your engine die unless it got so low in oil you locked up the crank bearing or something. Mine used to smoke a little bit, and I just kept riding it and kept it full of oil until I could rebuild it.
