Question on a Banshee
Old Sep 15, 2007 | 11:02 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default Question on a Banshee
take the clutch cover off and see if it's leaking through there
Old Sep 15, 2007 | 11:31 PM
Photog95's Avatar
Thanks for the reply. I was just getting ready to start a new thread about this. I already have the clutch cover off and the only place I can see where it could be happening is the O-ring where it passes through for the water pump. Does this sound like the most likely problem?
One other thing that I noticed is that if I take the radiator cap off it will shoot water right up in my lap just kicking it over. Could this be a serious problem or just something to go with the oily coolant?
The engine runs perfect, feels really strong, and doesn't appear to have any coolant getting into the combustion chamber, so I don't really suspect a head gasket or anything like that
Old Sep 15, 2007 | 11:51 PM
Speedy2222's Avatar
unless you have a compression leak... coolant will come out if u don't have the cap on..
Old Sep 17, 2007 | 12:19 AM
Photog95's Avatar
It just seems to run too strong to be loosing compression, but it also bubbles into the overflow tank under the sink as well.
Old Oct 19, 2007 | 09:35 AM
  #15
Solus's Avatar
I had the same problem with my RM 250 and it turned out to be a seal in the water pump. I ended up doing it myself. it wasnt too hard
Old Oct 19, 2007 | 03:07 PM
  #16
kawiking's Avatar
hmmm. wonder if that could be you impeller going bad and getting hot.
Old Oct 20, 2007 | 02:05 AM
  #17
rruser's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Photog95
<div class="FTQUOTE"><begin quote>Originally posted by: Speedy2222
carb slides are probably in backwards, make sure the angle part is facing the airbox</end quote></div>
Hi everyone. I'm new here, and just wanted to let everyone know that this post was a life saver. I would have never found this problem. I just bought a 2000 Banshee and it would not run under 3/4 throttle. I switched the carb slides around and it now purrssss like a kitten. Now I just need to find out why the tranny oil is getting into the antifreeze.</end quote></div>
Damn you speedy.. you took away one of my backwords slide fixes...
ah i'm just messing with ya. BTW, Your icon doesn't seem to show up.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
