2001 Wolverine carberator
Old 08-13-2007 | 05:06 PM
Yamahamaniac's Avatar
Default 2001 Wolverine carberator
If you get a k&n air filter and a pipe, could you go up to a 38 mm carberator and see a performance increase all around. What is the stock mm carberator thats on a 2001 wolverine 350 4x4
Old 08-13-2007 | 07:38 PM
OhHell's Avatar
Stock on an '01 is a MIKUNI BST34/1.....being a 34mm.
I think you would run into problems going to a 38mm.
If memory serves me correct a Warrior has a 35 or 36 mm carb.
I believe that would be the route to take.
Old 08-13-2007 | 08:36 PM
Jasonp's Avatar
Is the BST a CV carburator? You could go that big of a carb but you'll feel a loss in the low end and gain it back on the top, also response would suffer. I would recomend like a warrior edelbrock carb as it's a little smaller then most aftermarket carbs but will give you great response and torque. Basically going bigger would mean slower throttle response but more top end hp. Smaller the carb more torque and low end power with great response.
Old 03-27-2009 | 12:17 AM
brngrhd's Avatar
so you would not use this kit?
Keihin 38mm PE Carb Kit (thumb or twist)
#K-CR38E-Y $229.00
Includes; Carb, manifold adaptor, twist throttle & cable or cable to work
with stock thumb throttle. Must use Pro Flow Flange & Filter
Old 03-27-2009 | 07:16 PM
LotusPosition's Avatar
Mickey Dunlap ran the 435/446/500 Wolv motors on the stock carb, so it should be enough for a stock displacement.
I did run a Warrior carb on my 366 Wolv, I doubt that it increased HP.
r1pilot83
Utility ATVs
15
11-26-2019 12:39 AM
35dodge
09-29-2015 10:40 AM
jsmit116
09-18-2015 11:34 PM
Bonzhonda300ex
TheATVSuperStore
09-17-2015 02:21 PM
chewy78
09-08-2015 11:37 AM
