help with 350 raptor
Old Aug 18, 2007 | 08:13 PM
hollybolly's Avatar
Default help with 350 raptor
I have a 2005 350 Raptor. I bought a new clutch lever and assy housing. I removed the parking brake lever as this unit replaces that. My question is, there is another cradle adapter that the clutch lever fits into that depresses a little pin. This housing does not fit onto my new housing. What is this braket for? I traced the wire but it goes into my wiring harness. The bike works fine with out it on. Any help? thank you.
Old Aug 18, 2007 | 10:05 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
any wires coming FROM the the parking brake lever that go into the harness can be disconnected... 2 of them plug into one another.. the other just hangs.. and i am not sure exactly what "housing" u are talking about
Old Aug 18, 2007 | 11:36 PM
hollybolly's Avatar
Thanks for your response. The other bracket I was talking about has a little pin type mechanism that when the clutch lever is all the way pulled in, it depresses this little pin inside a housing. The new lever says it eliminates the need for the parking brake. So me and my son installed the new lever and assy today. Then I noticed this other bracket that the clutch lever sqeezes into. I just let it hang there while we tried it out. Doesn't appear to do anything. I just wondered what it was for or should I just cap off the connection?
Old Aug 19, 2007 | 12:56 AM
Speedy2222's Avatar
no need to cap it.. just unplug it.. there should be 3 wires u unhook from the harnes.s.. 2 plug into each other than the 3rd one hangs... the cable that goes from the clutch to the rear brake.. take off and throw away.. pickup a Parking brake block off plate when u get $10 the parking brake is the biggest waste of space on a quad... although.. TORS is just as bad.. and when the PB is adjusted properly( to where it works) it prematurely wears your pads
Old Aug 19, 2007 | 01:03 AM
hollybolly's Avatar
Thanks so much for the info. I've had two older Warriors before this. This one is just a little different. Bought my son a 250ex and it seems to be a good quad for him. I bought this one used but it seem to be in good shape. We're mainly woods riders. Thanks for your help.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
