fuel in oil
Old Aug 27, 2007 | 12:41 PM
RAPTOR27's Avatar
Default fuel in oil
i have a raptor 660 with a little fuel problem every time i shut it off i turn the fuel off and i still get fuel in the oil i know its not the fuel shut off ive had the tank on the ground for a week and didnt leak is it possible to be getting fuel in the oil while running
Old Aug 27, 2007 | 05:36 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default fuel in oil
you are either extremely rich, your spark is really weak, or your rings are shot
Old Aug 29, 2007 | 04:22 PM
03bansh33's Avatar
Default fuel in oil
If u dont have good spark the gas you dont burn is getting in your oil. Or if it running to rich you will not burn all the fuel, if that the case use smaller jet or put a pipe on it and use recommended jet for that pipe. Or your piston rings are bad if that the case it will smoke to.
Old Aug 29, 2007 | 04:30 PM
RAPTOR27's Avatar
Default fuel in oil
i tried putting smaller jets in and the thing would not run right and it doesnt smoke all the electronics are new including spark plug im not to concernd about it its just my back up 4wheeler
Old Aug 30, 2007 | 12:01 AM
zbysior's Avatar
Default fuel in oil
im guessing its the rings
Old Aug 30, 2007 | 05:45 PM
turkeythigh's Avatar
Default fuel in oil
im going to say it is deffinatly the rings
Old Aug 31, 2007 | 10:52 AM
quicksilver's Avatar
Default fuel in oil
it may well be the rings, but also remember that even with your fuel valve off, ther's still fuel in the line after the valve and in the carb yet. your float could be bad and the carb could be overflowing a bit and running into your intake, sure it wont be a lot since the fuel valve is off, but still there's some and after a couple times it will add up. i would try changing the oil, go out and ride a while, then come back, shut the fuel valve off and also drain the carb. do this every time you get done riding it. if you still have fuel in your oil, then you probably have rings that are going bad, but if you fuel in oil problem stops, then you're in for a carb rebuild and a float/float valve replacement along with verifying the float level is correct.
Old Aug 31, 2007 | 05:31 PM
Speedy2222's Avatar
Default fuel in oil
it will leak out of the bottom of the carb before it leaks into the cylinder
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
