Yamaha Blaster top end replacement
Old Sep 3, 2007 | 10:45 AM
jbrandona119's Avatar
Default Yamaha Blaster top end replacement
I was riding my quad one day but i guess i was on the throttle too hard for too long and the quad just died. I'm almost positive it's the top end because I just had it worked on (like inspected and cleaned) at a yamaha dealer.
Now I need to know how to install the gasket set. Any online sites or something?
Or should I just order a repair manual.
And I want to start modding my blaster too. I have an FMF exhaust pipe on there but i want to put on a fatty pipe and put in a jet kit and stuff. I just need to know how and where to start
thanks!
Old Sep 3, 2007 | 11:25 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
are you sure blew a top end gasket and not fried the rings? becuase replacing the gasket is not considered rebuildign the topend
Old Sep 3, 2007 | 11:40 AM
hmm...maybe. well even if that is the case then what should i do?
Old Sep 3, 2007 | 11:50 AM
Raptor450's Avatar
You need to pull the topend off and see what went wrong. More than likely you seized the piston, so when you take it apart you need to inspect your cylinder and piston for deep gouges. While you are in there you need to check the connecting rod bearing at the crank to make sure you didn't seize that up. Can you kick the engine over or is it locked up?
Old Sep 3, 2007 | 12:07 PM
Speedy2222's Avatar
test the compression
Old Sep 3, 2007 | 12:34 PM
ok i'm a total newb when it comes to this stuff but i really want to learn. it won't start at all and when i try and pop the clutch it just putters and dies. how would i test the compression?
Old Sep 3, 2007 | 12:36 PM
Speedy2222's Avatar
well.. #1.. make sure it has gas in it( it happens)
yeah it has gas.
lol
Old Sep 3, 2007 | 01:46 PM
oh and i tried taking the cylinder head off to check it out but i think i'm doing that wrong because the nuts and crap holding it on is REALLY tight.
Old Sep 3, 2007 | 03:37 PM
Doctorturbo's Avatar
GOT BOOST!
I was going to say hold up; but I guess that's too late.
Does this think kick over normal? Or does it kick over like there is very little compression?
Have you even pulled the plug? The plug can tell me a lot.
About the head studs. Yes the nuts are going to be tight. It's holding the head on and compression in the jug, so they have to be tight.
If you haven't broke anything loose yet, I would take Speedy2222 advice and do a compression test first.
