will a trimoto 125 engine fit in a 175 frame????
What the heck is a YT? I've seen ITs, DT's and YZs, but never a YT. Is that a dirtbike? If I had to guess, in my experiences, it would probably fit, but not without some modifications. The 125 engine will probably be smaller, so the engine brackets probably won't line up exactly. But at least there would be plenty of room for it. It's the opposite senario you have, but about 14 years ago I tried to put a YZ 250 engine into a YZ 125 frame, and it didn't work. Everything looked exacly the same, but everything on the 250 was just a little bigger - big enough to where it would be aggrevating to make it work right. Back then I didn't have the fabrication skills so I gave up on the whole project.
If you don't have any luck under the "Yamaha" forums you can try the "ATC 3 wheeler" forums on this sight.
KimSJoh
14
Jul 18, 2015 07:20 PM
