01 660 raptor starts when pushed
Old Sep 5, 2007 | 11:16 PM
shadyj69's Avatar
Default 01 660 raptor starts when pushed
ok i need some help my raptor starts when pushed very easy but with good charge it just cranks and puffs fule after its warned up it starts on its own what up please help
Old Sep 6, 2007 | 12:35 AM
zbysior's Avatar
I have a same machine and same problem.
I discovered that the second carb is not getting gas in the beggining.
When you cant start try to unscrew the drain screws(2x) from the bottom of the carb. Do it one by one and watch for fuel comming out. if its not comming out you can help by sucking on the drain line until it goes. Works for me every time. after it starts the gas gets sucked into the carb and than everything works ok.
this propably is fixable by taking the carb apart and cleaning it.....
hope that helps
Old Sep 6, 2007 | 06:50 PM
shadyj69's Avatar
ill give it a try thenks
Old Sep 7, 2007 | 06:15 PM
shadyj69's Avatar
no help it will just crank and crank you can smell fule coming lout the tail pipes but if i push start not even 5ft kick right over i dont understand
and after it been rode a lil it starts right up ????????????????/
BEEFKING69
Jun 17, 2015 12:38 AM
jayking232003
Jun 9, 2015 02:54 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
