axle barrings
Old Sep 10, 2007 | 11:20 AM
zoso's Avatar
Default axle barrings
how do i change the axle barrings on my 97 warrior, i cant seem to get the axle out of the hub. can you help please
Old Sep 10, 2007 | 02:29 PM
Raptor450's Avatar
The only way I have found is to remove the axle nuts, remove the left wheel and wheel hub, get a pipe or an old deepwell socket that will fit over the end of the splines on the axle and bottom out against where the wheel hub would bottom out. Then get a really big hammer and beat the crap out of it! DO NOT beat against the threads that hold the wheel hub bolt on. You will ruin your axle if you do that. Once your axle slides out, then you may have to get the old bearing races out of the bearing carrier. This is the fun part as I haven't found the secret to this except a lot of patience and hammering. You may can cut them in two with a grinder. I have cut them out with a torch before, but that didn't work too good, as I melted the carrier a little bit - WHOOPS! I usually replace the carrier at this point with a billett one with dual row bearings. The factory carrier is junk.
Old Sep 10, 2007 | 05:42 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
screw the castle nut on and beat on that... ya i melted the stock bearings in my warrior too... had to have them pressed out by the dealer
Old Sep 10, 2007 | 08:10 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Speedy2222
screw the castle nut on and beat on that... ya i melted the stock bearings in my warrior too... had to have them pressed out by the dealer</end quote></div>
Wow! Don't you think beating on the castle nut is a little risky? I almost ruined my threads by doing that one time!
Old Sep 10, 2007 | 08:29 PM
TRLYFZ450's Avatar
Then after you get the axle out, drill and tap the carrier and then install a grease zerk and pump it full. You will never have trouble getting the axle out again. It will also help keep water out and your bearings will last longer.
Old Sep 10, 2007 | 09:01 PM
Speedy2222's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
Wow! Don't you think beating on the castle nut is a little risky? I almost ruined my threads by doing that one time!</end quote></div>
not if u know what you're doing
Old Sep 10, 2007 | 10:36 PM
Raptor450's Avatar
not if u know what you're doing</end quote></div>
Please explain. Cause every one of my Warrior axles were stuck so bad I HAD to beat the ever-living crap out of it to get it out! And that wimpy little castle nut and threads were not designed to be beat on with a 10 lb. hammer. Since you " know what you're doing" , what's your secret? The last time I replaced mine, I had a piece of schedule 40 pipe slid over the splines and bottomed out where the hub stops, and by the time I got my axle out, the steel pipe I had used was mashed in about an inch where I beat on it. I don't care what you do, unless you have some kind of special tool, it just takes brute force, and the end of an axle wasn't designed to be beat on like that.
Valder
Nov 28, 2020 07:38 AM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
