checking oil ?
Old Sep 14, 2007 | 06:16 PM
TimberedWolf250's Avatar
Default checking oil ?
Kind of a dumb question but here goes...
I went to our local dealer 45 miles 1 way to get new grips and a rear brake cable, and asked about a winch mount. while I was there I asked 2 techs " what is the best way to check oil level in the crankcase?" 1 response was to unscrew the dip stick wipe and screw back in then remove and check.. ok i thought
next tech said " unscrew dip stick wipe and just set it in the opening then remove and check oil level do not screw back in."
so what is the best way?
I would hhave liked to ask a third tech there to get a possibly another answer LOL
or a 2 to 1 anyway
so that's the question
Old Sep 14, 2007 | 06:43 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i screw mine back in... acurate every time
Old Sep 14, 2007 | 08:57 PM
toddmh's Avatar
the yamaha manual says not to screw it in,so thats what I do..
Old Sep 14, 2007 | 09:41 PM
TwinCam95's Avatar
it kinda sucks that some bikes need the dipstick screwed in for the correct level reading, and others, even from the same manufacturer, need it resting on the top thread. I think it's to keep the sale of manuals steady haha. When I aquire a bike I am unfamiliar with, I get it so the oil is on the "low" side of the dipstick when it's resting on the top thread. That way if it's a "don't screw in" bike, the level is still acceptable, and if it's a "screw it in" bike, I haven't overfilled. Then when get a chance, if I even keep the bike, I get the correct answer and re-check.
Old Sep 15, 2007 | 11:48 AM
skramblr's Avatar
RTFM - Do what the manual says. Instructions for checking the old can be bike dependant. But doing it either way probably won't hurt the bike.
Old Sep 16, 2007 | 10:23 AM
420Pimp's Avatar
LMFAO... WOW Just use a little common sense. If you screwed it in there would only be a 1/4 of an inch difference so it dosnt matter either way. The oil marking gap is way to big for 1/4 inch to evan be a problem. Just make sure the stick reads oil on it.
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
