Raptor Steering Stem Replacement help needed
Old Sep 21, 2007 | 08:02 PM
Duramax's Avatar
Default Raptor Steering Stem Replacement help needed
I need to change the steering stem on my '01 Raptor. I have the plastic, etc. removed and now need to remove the stem. I could use some help on how to remove the tie rod ends on the pitman arm. Does the stem slip out of the pitman arm or does it need to be pressed out? When you remove the nut on the bottom of the stem, will the shaft slip out of the pitman or is there more to it than that? Any help will be appreciated.
Old Sep 21, 2007 | 08:37 PM
velocyraptor's Avatar
remove the nut and pull the stem out, if you want to remove the tie rods from the pitman hit the pitman right next to the ball joint so it falls. shouldnt be a problem
Old Sep 21, 2007 | 08:54 PM
Duramax's Avatar
I don't want to remove the tie rods or pitman if I don't have to. So, you are saying I can just take the nut off and it will slip out? Sounds good to me. Didn't think it would be that simple. Nothing I do is simple. I live by Murphy's Law. Thanks a million.
Old Sep 22, 2007 | 10:50 PM
put take the nut off and loosen the bolts infront of the tank and pull
Old Sep 23, 2007 | 11:06 PM
Duramax's Avatar
Got 'er done! Thanks to all.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
