WARRIOR NEED HELP
Old Oct 10, 2007 | 07:24 PM
  #21
STRAIGHTUPDAHILL's Avatar
Default WARRIOR NEED HELP
DIRT GOES THROUGH SCREEN
FILTERS HAVE A SMALLER MICRON FILTRATION
Old Oct 11, 2007 | 12:18 AM
  #22
Jasonp's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: STRAIGHTUPDAHILL
DIRT GOES THROUGH A SCREEN</end quote></div>
Old Oct 11, 2007 | 12:22 AM
  #23
Jasonp's Avatar
YOU HAVE A CAPS LOCK BUTTON.. USE IT.
WHAT DO YOU THINK YOUR FILTER THAT YOU STUCK IN THE LINE HAS IN IT?? ALSO FUEL VAPORS ARE PUSHED OUT OF THE LINE, IF YOU CAN ACTUALLY GET DIRT OR MOISTER IN I'D GIVE YOU A DOLLAR.
Old Oct 11, 2007 | 01:25 AM
  #24
Williebee's Avatar
Good tip's to check , but don't forget the Airfilter ; if it get's clogged up it can cause the engine to stumble and stall out your engine completely when it get's dirty ! And there should be a screen type fuel filter on the petcock/on /off/reserve valve , when you get the carb cleaned i would install a clear inline fuel filter between the fuel tank and carb ; and put some SeaFoam in the gas tank it's cheap insurance to keep your fuel system clean ! And with the clear inline fuel filter you can see at a glance if you get dirt or water in your fuel , you can get the fuel filter from any small engine repair shop for between 4 or 5 buck's clamps included ; and the SeaFoam at most auto parts stores ! I get it at O'Reillys Auto Parts Stores for 5.99 plus tax ! SeaFoam is a fuel cleaner/stabilizer that will clean the fuel system and the conbustion chamber of built up carbon deposits ! .........
Old Oct 11, 2007 | 03:02 AM
  #25
Drain your bowl often..
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
