yfz450 Miss Problem
Old Oct 12, 2007 | 05:49 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default yfz450 Miss Problem
Since I bought this yfz it has had a problem with missing at the high rpm range when I really get on it. No problems idling or at any other time. I've cleaned the carb and I don't think it's a fuel problem.
The guy I bought it from said he put a new stator in it. I'm thinking either he was chasing the problem or it is the problem. Someone recommended replacing the rev box saying that it may be bad.
What do you guys think?
Old Oct 12, 2007 | 06:19 PM
STRAIGHTUPDAHILL's Avatar
main jet to small
Old Oct 12, 2007 | 06:25 PM
Koopa's Avatar
Changed it. Actually bigger than recommended by dynojet.
Old Oct 12, 2007 | 07:36 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
check the timing.. if he replaced it.. it may be off a degree or something
Old Oct 12, 2007 | 08:56 PM
Quad-Maniac's Avatar
Check your plug gap.
Old Oct 12, 2007 | 09:12 PM
dustinjustin3's Avatar
does it have the stock pipe on it.. my buddy had the same problem and it had no power with his when it was new and we took the tip off and it ran fine after that. if not what pipe do you have and what jets are in it.
Old Oct 13, 2007 | 12:36 AM
then maybe to rich..
Old Oct 13, 2007 | 06:52 PM
Koopa's Avatar
Not stock (check sig), not rich (checked jetting), gap good. Thanks for the suggestions though guys, much appreciated.
Good suggestion speedy on the timing. To make sure I know what I'm talking about I need get to top dead make sure cam chain marks line up then make sure the T on the other side of the case if visible thru the hole? Thats how I did it on the 400ex anyway.
skinnyr6
Aug 25, 2023 02:18 AM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
blpersinger
Jul 15, 2015 09:56 PM
steveo612
Jul 11, 2015 08:35 AM
