ok what psi?
Old Oct 24, 2007 | 10:11 AM
mechanicock's Avatar
Default ok what psi?
Whst psi should i run in these mudlites, they are really stiff considering that they are a 6 ply tire, so my question to any of you is; How much air should be in my tires for trail riding?
thanks for reading
Old Oct 24, 2007 | 11:09 AM
54warrior's Avatar
A friend has a Honda Foreman 450 with those tires and doesn't put any air in them. Hasn't had any probs yet!!
Old Oct 24, 2007 | 01:32 PM
STRAIGHTUPDAHILL's Avatar
I DON'T USE AIR EITHER..I USE NITROGEN
Old Oct 24, 2007 | 01:46 PM
kurt1011's Avatar
i run 8 lbs in the front and 5 lbs in the back. take a minute and read this post - very informative http://forums.atvconnection.co...atid/5/threadid/522027
Old Oct 24, 2007 | 03:26 PM
ok so i can either use no air, nitrogen or run 8 in the front and 5 in the back.?
so i guess its just a matter of how you ride, but poppin wheelies and slinging the rear end around seems like it would be easier with not as much air in the tires, i assume my assumptions are correct, tonight im going to lower the fronts to 8 and the rears to 5, and feel it out.
thanks for responding
Old Oct 24, 2007 | 03:40 PM
I WOULDN'T USE NITROUS
Old Oct 24, 2007 | 04:30 PM
yeah well unless i want to blast off your right......!!!!
well why nitrogen, because its lighter than air? or am i way off base?
Old Oct 24, 2007 | 05:15 PM
MORE STABLE THROUGH TEMPERATURE CHANGE
Old Oct 24, 2007 | 05:22 PM
ok, i used to put nitrogen in trailer tires when traveling long distances through alternating climates, i got you, but how much does a tank of nitrogen cost these days?
Old Oct 24, 2007 | 08:44 PM
I keep a paintball tank full in the car all the time...i fill my little tanks of of my big tanks at my shop..they cost me 45 to fill..but i only need to fill them every couple years
