Splitfire Plugs...
Old Oct 27, 2007 | 12:28 AM
  #21
WVWOLVERINE450's Avatar
Default Splitfire Plugs...
Ive always had good luck with NGK plugs, but I will be running Iridiums from now on, less voltage and a much longer life, ya get what ya pay for.
Old Oct 27, 2007 | 01:09 AM
  #22
Jasonp's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: STRAIGHTUPDAHILL
BASICALLY IT BOILS DOWN TO THIS!
DON'T HOLD THE COIL WIRE WHILE HITTING THE START BUTTON.</end quote></div>
if you think that is bad you should try 120vac, coming out of the wall.
Old Oct 27, 2007 | 01:21 AM
  #23
STRAIGHTUPDAHILL's Avatar
120 IS NOTHING..NOW 50,000 FROM A NEON TRANFORMER GETS YOUR FINGERS TOASTING..LOL
Old Oct 27, 2007 | 01:23 AM
  #24
Jasonp's Avatar
120 IS NOTHING..NOW 50,000 FROM A NEON TRANFORMER GETS YOUR FINGERS TOASTING..LOL</end quote></div>
It really isn't about the voltage it's about the amps.. Why are you *****ing yelling on every thread?
Old Oct 27, 2007 | 01:25 AM
  #25
HAD 220 FROM ARM TO ARM..THE MAINTAINANCE GUY "FIXED" THE LIGHT ON A MACHINE.. I TURNED IT ON..BAM.. THAT KICKS THE HEART PRETTY GOOD
Old Oct 27, 2007 | 01:27 AM
  #26
Jasonp's Avatar
HAD 220 FROM ARM TO ARM..THE MAINTAINANCE GUY "FIXED" THE LIGHT ON A MACHINE.. I TURNED IT ON..BAM.. THAT KICKS THE HEART PRETTY GOOD</end quote></div>
Yeah, I believe you. Have you heard of caps lock? Do you like to ***** threads?
Old Oct 27, 2007 | 01:31 AM
  #27
other board i use drop them automatically..i forget sometimes to hit it
Old Nov 5, 2007 | 11:01 AM
  #28
rkhrdjp's Avatar
moved reply
Old Nov 7, 2007 | 09:39 AM
  #29
strike_fly's Avatar
I have never seen a Champion plug get a bike through a whole days ride.
Only plug i would run is NGK
Ask the Editor
Jun 3, 2015 04:16 PM
hopalong
Jun 21, 2005 10:40 PM
MNWolverine01
Dec 27, 2004 07:04 PM
anchor
Nov 10, 2003 10:42 PM
LakotaSportRider
Aug 18, 2002 10:07 PM
