350warrior stator wires
Old Nov 8, 2007 | 01:14 PM
Xtreme26181's Avatar
Default 350warrior stator wires
do i need to drain the oil, b4 i remove the old stator off my 350 warrior?
Old Nov 8, 2007 | 08:26 PM
8hours l8er and i had to call a shop..the answer was yes..thanks 4 the help lol
1 more question any1? I bought an ebay motor for my quad, the motor is a 89 and my 350 warrior is a 94.. the stator on the 89 has an extra green solid wire, any1 know were it goes? it was on the plug with the blue and yellow wires but it was only a 3 prong plug and my 94 is a 4 prong plug so i had to cut and reconnect some wires but im left over with a solid dark green wire and have no place to put it and my quad isnt running as good as it was with the old stator
b4 my old stator went bad it wouldnt start but would run great if i bumped it, now it will start great but wont run worth a **** [img]i/expressions/face-icon-small-sad.gif[/img]
so.. 89 motor with a extra green wire?
94 warrior.. dont see a place for this wire
Old Nov 9, 2007 | 10:23 AM
HEEEELPPPPP PLEASE!!!!!
89stator... 3prong 3white wires ..connected
4prong 1 wire missing, making it 3 wires in a 4 prong plug..wires are dark green, blue and yellow cut out green wire and connected plug to my 94 plug on bike after i pulled the red and a white with green dots wire out of 94 bike frame plug.
84 stator has left over white with green dots wire that i connected to white with a green solid line wire on 94 frame.
connected red to red.
now on the 89 stator end im left over with this solid green wire that originaly was in the 4prong plug that was missing the red and white with green dots wire.
and b4 my bike wouldnt start, i had to jump it in gear down hill.. ran great.
now 89 stator on it..starts great 1st fire but wont run worth a damn like its missing or lack of fuel .. but it has to do with this green wire left over cause bike ran great with old1, just wouldnt start and i had my bike put in time and valves adjusted by a pro at the shop...im lost
Old Nov 13, 2007 | 07:56 PM
2yam350's Avatar
the green wire on the 89 goes to the cdi box 13 wires on 89 cdi box12 on 94 box, u should get stator for right year before u fire something
Old Nov 13, 2007 | 07:57 PM
2yam350's Avatar
or use cdi box from the 89
Old Nov 13, 2007 | 10:56 PM
Raptor450's Avatar
I know it's a little late now, but you really need the right stator for your year model.
Jmuddin284
Jan 19, 2026 07:16 AM
bradco
Aug 21, 2015 08:11 PM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
