Oil filter change on grizz
Use one of the socket wrench style oil filter wrenches, and use two of three ratchet extensions to connect the filter wrench to a ratchet. Then just reach in from the left front fender opening with your ratchet and extensions with the filter wrench already on it, and simply unscrew the filter. Pull the old filter back out from under the Grizzly with it still in the filter wrench. Then put the new filter in the filter wrench, guide it in place, and tighten it down. Takes about a minute to change.
DV
DV
