exhaust glowing
Old Nov 18, 2007 | 07:01 AM
bgbass.1's Avatar
Default exhaust glowing
Have a 04 660 grizzly carb.had bad needlee valve for fuel flow replaced that put back together started right up but the exauhst pipe at motor gets red hot now. Not sure where to look i figure carb. is running very lean cant find any adjustments to riching it up any suggestions on where to go now. thank you
Old Nov 18, 2007 | 11:35 AM
DesertYFZ450's Avatar
what is your jetting at right now? sounds like you are probably a little lean, but can't really help you out without knowing what you are jetted at right now, try going down on the main a little
Old Nov 18, 2007 | 12:08 PM
bgbass.1's Avatar
its the jet they put in at the factory all that was done it wasnt getting gas and when i took apart needle valve was aluminum and no good replaced with stainless now carb. fills and runs great just cant figure why it would run lean now never touched main jet.
Old Nov 18, 2007 | 01:10 PM
is the needle that you replaced it with an adjustable needle?
Old Nov 18, 2007 | 03:48 PM
Doctorturbo's Avatar
GOT BOOST!
Check the float level.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
