Wolverine FST 488 kit installed REVIEW
#22
Thats the same thing I ran into with the Mikuni carb I tried, but the kit came with some spacers to put under the tank to raise it up to clear the top cable that came out the cap on the round slide carb. If it isn't too close, you could try a small spacer to raise the tank slightly.
#24
#26
#27
I was looking at them and they are quite a bit bigger,(39mm on the yfz450 (plus it has a throttle position sensor) verses 33mm on the wolverine). So I was told that it would be too big and that it would bog down too much.\
Raptor 350 is 3mm bigger but it is still a mikuni that depends on the engine vacuum to pump the fuel so it will help but not as much as a 35mm or 37mm keihin fcr carb.
