Problem with wolverine 450
Old Nov 23, 2007 | 01:18 AM
Polishyfz450's Avatar
Default Problem with wolverine 450
For some resin its not getting and gas flow into the engine and chocks and then dies
Old Nov 23, 2007 | 03:19 AM
recon99's Avatar
Are you getting fuel into the carb? Have you checked the floats and cleaned the carb yet? You could even try tapping on the side of the carb with the handle of a screwdriver or something, sometimes a float valve will get hung up and you can get them loose just by tapping on the carb. Most likely the same thing will happen again eventually in this case though.
Old Nov 23, 2007 | 12:25 PM
ctateusa1's Avatar
check air filter too
Old Nov 23, 2007 | 04:43 PM
I did notings wrong with the air fillter
Old Nov 23, 2007 | 04:46 PM
recon99's Avatar
Did you make sure that you're at least getting fuel out of the petcock?
Old Nov 23, 2007 | 04:59 PM
were is the petcock located and what does it do ?
Old Nov 23, 2007 | 05:15 PM
ctateusa1's Avatar
fuel petcock is on left side by gear shift, under the gas tank, disconnect a hose from it to the carb and see if gas runs out.
Old Nov 23, 2007 | 06:26 PM
yotatrailrunner's Avatar
Is the fuel petcock turned on?
Old Nov 23, 2007 | 07:22 PM
wat specificaly is a petcock would u be able to send a picture of it and descriptive directions?????
Old Nov 23, 2007 | 10:42 PM
It is on the left side of the fuel tank were your knee is.
