2003 Bear Tracker gear shift
Old Dec 3, 2007 | 08:11 PM
Browninga5's Avatar
Default 2003 Bear Tracker gear shift
I have a 03' Bear Tracker, if you shift into reverse then into foward,it wants to keep popping out of gear.Is there a adjustment for this? Any sugestions?
Old Dec 3, 2007 | 09:54 PM
headpressure's Avatar
Yes there is.
It's the rod that connects the F-R lever to the transmission. You will most likely need to lengthen the rod a little with the adjustable ends on the rod so that the gear gets pushed all the way in when you shift it into Fwd.
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Chuck188
Jul 17, 2015 02:45 PM
sara durrant
Jul 6, 2015 05:32 PM
