Another Warrior Starting Issue
Old Dec 7, 2007 | 06:38 PM
ABN82MP's Avatar
Default Another Warrior Starting Issue
Hey guys,
I've searched and searched, but I can't find the answer to my problem here.
I have a POS 99 Warrior. I spent the day on Wednesday pulling my daughter around in the snow. When I went to put it back in the garage I stalled it and now it wont start back up.
I turn the key into the on position and I can get the lights to com on, but there is nothing when I push the starter button. No clicking, no buzzing, nothing. I had thought it was the fuse till I read that this is an inline fuse on the positive battery wire. If that was blown I wouldnt get lights. If it were a bad selonoid I would expect to hear it buzzing or clicking, right?
Any help here is greatly appreciated.
Old Dec 7, 2007 | 11:23 PM
Raptor450's Avatar
Check to make sure the big black negative battery terminal is still on the battery. If this breaks off, you lose ground to the engine starter but the small black ground will still run the lights. I had one that the starter button would work about half the time. You had to wiggle it just right to get it to work. It was like a redneck anti-theft device.
Old Dec 8, 2007 | 09:09 AM
ABN82MP's Avatar
Thatnks for the response. I checked the battery hen I was messing with it last night. I'll mess with the switch a bit and see if thats the problem. How would I go about hot wiring the switchif it's bad?
Is there anything else I should check besides the battery wire and the switch?
Old Dec 10, 2007 | 12:21 AM
ABN82MP's Avatar
bump
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
