Recent Raptor GPS speeds?
Old 01-11-2001, 08:55 PM
No2StrokeBs's Avatar
I weigh 195lbs and my Raptor went 75mph, My scrawny-*** friend weighs 145lbs and he went 76.4 on the same bike, but his Raptor only went 74mph with him on it, guess i got lucky and got the stronger bike
  #22
Old 01-11-2001, 09:03 PM
ScoobyDFW's Avatar
I wonder if location has something to do with the accuracy? I just turned on my etrex and it took a very long time to track the satellites and then it said accuracy 197 feet. But then a few minutes later it said 126 feet accuracy, then 26 feet accuracy, then 42 feet accuracy. I am not even moving. Then I turn it off and then back on and it says 115 feet accuracy, then back down to around 38 feet accuracy. I have gotten low signal warnings when out riding, which of course interferes with my speed measurement. Also, the lag seems more than 1 second to me.
  #23
Old 01-12-2001, 01:51 PM
dosperado's Avatar
And its important that the GPS be firmly mounted on the vehicle to get an accurate top speed. I have seen results range pretty widely when it is just held in hand or flopping around in a pocket or along those lines. And level ground too.
  #24
Old 01-14-2001, 05:36 PM
quad500/650's Avatar
gps speeds today
ds650 70mh rider 180lb
raptor 70mh rider 140lb
the temp was 30f we ran on paved roads but it was coold i was realy disapointed in this speed check. i will post again when the weather changes.
  #25
Old 01-14-2001, 07:15 PM
badraptor's Avatar
75.3 mph 33 degrees biggun complete exhaust ,150,155 mains still to lean ,the bike has more power just needs more fuel i should get 160,165 in tommorow,200lb rider
  #26
Old 01-15-2001, 12:06 AM
slickster's Avatar
My Banshee,
86.9mph on the pavement.
140lb rider.
  #27
Old 01-17-2001, 07:22 PM
fast400's Avatar
i had my 99 400ex clocked at 71mph. mods include e-series pro meg exhaust. k&n filter and dyno jet kit.
  #28
Old 01-18-2001, 12:21 PM
Raptorrider2001's Avatar
BlueReptile- You mentioned that your GPS had a tripometer on it. Have you ever used it to check how many miles you can run without having to refuel the Raptor? Thanks
  #29
Old 01-18-2001, 12:32 PM
BlueReptile's Avatar
Raptorrider2001,
Sorry, never used it to gage the range of the fuel tank. However, a tank of gas usually lasts me about 2 - 2 1/2 trips, with each trip about 10-15 miles. Most of it is trail riding. These are very rough numbers though...
  #30
Old 01-18-2001, 11:19 PM
Banshee96D's Avatar
I think that GPS's are great, but everyone should check out the Panoram computer for atvs and dirt bikes. Look at www.trailtech.net for the computer. It retails for $59.95.
Quick Reply: Recent Raptor GPS speeds?
