Got it stuck
Old Jan 8, 2008 | 11:51 PM
ctateusa1's Avatar
Default Got it stuck
<div class="FTQUOTE"><begin quote>Originally posted by: mdebuck
well i've never messed with a wolverine so i was just sayin it could ahve hydrolocked but i definitely agreed on ur advice cstateusa on blowint the water out of the cylinder....</end quote></div>
Not a problem and I definetly agree with you on the fact that you can definetly bend a rod on anything by hydrolocking it.(we had a $50k acura in the shop last year with 2 bent rods due to driving through a low water crossing.)
I think a lot of it has to due with what rpm you are running and also how long the rod is(I would think a longer rod would bend easier)
Mine went under at pretty much idle so I knew I couldnt have hurt it bad.
Gotmudd!'s Avatar
sounds like you did everything the dealership would say to do. just make sure that the cvt is drained and dry!
Old Jan 9, 2008 | 12:20 AM
2FAST4URASS's Avatar
What is HYDROLOCKED ? ive sunk my raptor 4-5 time's up to the top of the seat and do the normal route pull the spark plug out and flip it on end turn over to pump out watter take the air filter out get it dryed up and go on and ive have to yet have any problems mine..
Old Jan 9, 2008 | 12:52 AM
Gotmudd!'s Avatar
hydro lock is when water get in the cylinder and builds pressure up and bends the push rods
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
