87 warrior accelerator pump
Old Jan 31, 2008 | 01:53 PM
87 warrior's Avatar
Default 87 warrior accelerator pump
when i hit the throttle quick it bogs down and if i hit it quick and hold it, it cuts out. i believe it's my accelerator pump.? my question is does anybody know how to fix it? is it just replacing the rod set (rod, spring, and little rubber boot) or is it more indepth? i was thinking mybe i would have to do something with the plastic lever behind the throttle but i'm not sure.
also the other day i noticed that my rear shock is leaking???? does this mean it's time for a new one or is it fixable???
Old Jan 31, 2008 | 03:32 PM
pmcc37's Avatar
have you checked your parking brake or reverse rev limiter? that could be you problem. and as far as a shock, I may have one for you next week, whenever i get the new ones for my 97.
Old Jan 31, 2008 | 03:47 PM
87 warrior's Avatar
i have an 87 the 87's don't have a rev limiter
Old Jan 31, 2008 | 04:12 PM
pmcc37's Avatar
well then its not that. I haven't ever worked on any of the pre 94' warriors
Old Jan 31, 2008 | 05:32 PM
87 warrior's Avatar
well i ran a test to see if my accelerator pump is working and it's deff. not working. now i just need to know if changing the rod set is the fix or if it's something more than that......?
Old Jan 31, 2008 | 06:48 PM
95wolv's Avatar
I'm assuming the carb is the same as the other Warriors I've seen, the accelerator pump is a problem with them, the spring is extremely weak, causing the pump rod to jam down and stay down. The best thing to do is to take the bowl off, clean out the passage and make sure the rod isn't hanging up, then replace the spring with one from an ink pen, the old click style. The spring is the same length and diameter, but about 5 times stiffer, making sure the rod always goes back. I used one in my 95 Wolverine (same carb as Warrior,until they changed it in 96), and neve had a problem in years.
Old Feb 1, 2008 | 12:03 AM
87 warrior's Avatar
sounds like a cheap easy fix. i'll have to give that a try. hopefully it works for me.
Old Feb 1, 2008 | 05:36 PM
87 warrior's Avatar
here's the update..... i took the carb apart today to fix my accelerator pump and come to find out there was no nut holding the arm that lifts the rod to pump the fuel, it fell off and was laying on the side of the cover. so i put it back on and put a nut on it and i also did that ink pen spring and BAM works perfectly now.
thanks for the help
Old Feb 1, 2008 | 05:42 PM
mechanicock's Avatar
thats awesome ill keep that in mind if i ever experience anything like that!!
Old Feb 1, 2008 | 05:45 PM
87 warrior's Avatar
yea i didn't think it would work but it did. i was suprised lol.
exmotocrosser
Sep 13, 2019 06:12 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
BYC
Sep 25, 2015 02:10 PM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
