Warrior Issues
Old Mar 4, 2008 | 01:41 AM
FordNut5's Avatar
Default Warrior Issues
Thanks, ill see if that helps this weekend
Old Mar 4, 2008 | 01:59 PM
87 warrior's Avatar
let us know how it works out
Old Mar 4, 2008 | 02:07 PM
FordNut5's Avatar
Ill do that, one more question, how many turns out should the air fuel mixture screw be?
Old Mar 4, 2008 | 02:11 PM
87 warrior's Avatar
well stock is 2 turns out. but since you have a filter it would probably need to be about 1 1/2 - 1 1/4. but i'm not really sure. that is something you have to mess around with to get it right. and the only way to get it right is to do a plug reading.
Old Mar 4, 2008 | 02:15 PM
  #15
FordNut5's Avatar
Thanks Ill play with it this weekend and see if i can get it right
Old Mar 4, 2008 | 10:02 PM
  #16
beefy46172's Avatar
Loves To Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: 87 warrior
well stock is 2 turns out. but since you have a filter it would probably need to be about 1 1/2 - 1 1/4. but i'm not really sure. that is something you have to mess around with to get it right. and the only way to get it right is to do a plug reading.</end quote></div>
Uh, I believe you have it backwards bro. With that filter he would need to back it out further.
Old Mar 4, 2008 | 10:12 PM
  #17
FordNut5's Avatar
So 2 to 2 1/2 turns
Old Mar 4, 2008 | 10:33 PM
  #18
87 warrior's Avatar
yes, i'm sorry. 2 - 2 1/2
in is lean and out is rich. so yes the filter causes more air flow which makes it leaner. so turning your mixture screw out will enrich the mixture which is what you want.
thanx for the correction beefy lol. sometimes it can get confusing.
Old Mar 4, 2008 | 10:35 PM
  #19
FordNut5's Avatar
Thanks for the help, Ill work on it some more this weekend and let you guys know how it goes.
Old Mar 4, 2008 | 11:32 PM
  #20
FordNut5's Avatar
Could the diaphram be bad?
