Warrior Issues
Old Mar 4, 2008 | 11:46 PM
  #21
87 warrior's Avatar
Default Warrior Issues
it's a posibility if the diaphram is cracked or warped/dry rotted it could be bad. it doesn't hurt to check it though.
Old Mar 4, 2008 | 11:47 PM
  #22
FordNut5's Avatar
Any idea were to get a replacement diaphram, I'd think that'ed affect the whole throttle range
Old Mar 4, 2008 | 11:50 PM
  #23
87 warrior's Avatar
i think the diaphram only controls the idel circut but i'm not positive. i would think you could order one online at bikebandit.com or worldofpowersports.com they have one in there somewhere.
Old Mar 11, 2008 | 12:39 AM
  #24
FordNut5's Avatar
I can't seem to get this one figured out. I tried moving the needle position both up and down, I tried adjusting the air fuel mixture. And i can't seem to get it figured out. It doesn't have a air leak that i can find (tried the W D 40 trick) The only thing i havent tried is changing the main jet, but the Yamaha service tech said that probably wasn't my problem when i went to pick one up. I think this one's going to have to go to the Yamaha dealer to figure out.
Old Mar 11, 2008 | 01:15 AM
  #25
87 warrior's Avatar
what size jet did you get? if you haven't changed the main jet yet i would do so. if it's spitting and backfiering at or around 1/2 throttle it's probably your main jet. the main jet controls 1/2 to full throttle. so i would try changing the jet first before you spend money out the ***.
Old Mar 11, 2008 | 01:25 AM
  #26
FordNut5's Avatar
I was going to put a 150 in. I got to talkin with the service tech at the dealership and he said that that probably wasn't my problem, but i think i'll put it in before i take it to the dealership. Thats my last option unless you got any more ideas. Thanks alot, i apreciate all of the help
Old Mar 11, 2008 | 01:59 AM
  #27
87 warrior's Avatar
not a problem, that's about all i can think of.... i hate to run out of ideas on you. but i would try the 150 main and see what happens. lets us know what happens.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
