warrior problems :/
Old Mar 12, 2008 | 07:42 AM
embler's Avatar
Default warrior problems :/
its right behind the big cover next to the one over the oil filter cover. its just a few bolts and disconnecting some wires. just pay attention on how you take the old one out and put the new one in the same way.
Old Mar 12, 2008 | 11:02 AM
pmcc37's Avatar
Since your going to replace the stator go to rickystator and get one from him, the are about the same as a factory and much better. Very easy to replace.
One way to check your stator. Will your lights work if you pull the fuse going to your battary and pull start it? If not our stator is bad.
Old Mar 12, 2008 | 09:00 PM
wwarriorrider350's Avatar
could i get a rickystator with 150$?
Old Mar 12, 2008 | 11:30 PM
scrambler45's Avatar
i had 04' warrior do the same thing! i put a new stator in it and about a month later everything jus quit. i messed with it until i was over it but yeah its the stator. i paid $130 for one but don't remember who from
Old Mar 13, 2008 | 09:36 AM
  #15
pmcc37's Avatar
http://www.rickystator.com/
You should be able to find it, I didn't have time to look, but i think theirs runs in the $150 range.
Old Mar 13, 2008 | 11:40 AM
  #16
ok. and one more thing.
would a strator off another four wheeler work?
like a z400?
or trx450
Old Mar 13, 2008 | 11:43 AM
  #17
pmcc37's Avatar
nope, but one off a 350 woly or big bear should.
Old Mar 13, 2008 | 11:54 AM
  #18
ah okay. j.w does anyone have a pic of where the stator is?
Old Mar 13, 2008 | 12:03 PM
  #19
pmcc37's Avatar
if your sitting on the bike its the round piece above the shifter that gets in your way. well in there....
Old Mar 13, 2008 | 12:09 PM
  #20
is it very hard to remove?
