warrior drain plug hole stripped
Old Mar 19, 2008 | 01:21 PM
pmcc37's Avatar
Default warrior drain plug hole stripped
<div class="FTQUOTE"><begin quote>Originally posted by: toddmh
<div class="FTQUOTE"><begin quote>Originally posted by: jd630
warrior drain plug hole stripped in case. Does anyone know any repair options other than a helicoil. If not do they make a helicoil for that application? Being that the case threads are so shallow, only like a 1/4" of threads. Most regular helicoil applications are about an inch.</end quote></div>
Welcome to Yamaha..</end quote></div>
No that was funny..
By the way I can't even get mine out of my machine.
Old Mar 19, 2008 | 01:57 PM
woodsjunky's Avatar
that strainer is a direct filter for ur oil pump thats how u pickup and redistribute the oil into the topend u need to keep that in there it is vital for the life of ur oil pump if u get some thing in there that allows it not to turn it will shear off the nylon gear that drives the pump
Reactant
Mar 30, 2022 02:08 AM
SDR-II
Sep 29, 2015 01:06 AM
ghost civic
Jul 19, 2015 10:13 AM
Reactant
Jul 16, 2015 10:29 PM
Coryco
Jul 6, 2015 07:30 PM
