Blaster Only sparks sometimes
Old Apr 2, 2008 | 10:28 PM
Mlarkin_09's Avatar
Default Blaster Only sparks sometimes
Rode it for about 5 to 7 hours on saturday ran great. I put it in the shop for the night. The next day I went out It started just fine but ran like crap back fired and sputtered like a fouled plug. Took the plug out and it was sparking bright blue. Put the plug back in and it wouldn't start at all. Took the plug back out and No spark. It will only spark about half the time. I put a new plug Cdi and Coil on and it still is doing the same thing. I took the fly wheel off and the key is in good shape. Some times it will spark 20 to 30 kicks in a row. Then maby 50 with no spark then Start sparking for a few kicks. I have no idea maby the stator is bad but I dont have access to one and I am really tired of buying new parts and not fixing my problem.
Old Apr 2, 2008 | 10:49 PM
qsportgoat's Avatar
i 've never heard of a stator failing with an on/off symtem they usually fade or just die. i'm thinking more like a loose or grounding wire. i say you should trace all wires look for a short and check each connector making sure there plugged. my sons blaster quit 2 months ago and it was the tors which failed. i removed it and it fired right up. not saying this is the same but just showing example of annoying elec. problems . good luck
Old Apr 3, 2008 | 12:44 AM
FordNut5's Avatar
Check your ground connections, think of your spark like the lights on a trailer, if it doesn't have good ground you don't have lights but when you get a good ground you have lights. Hope this helps.
Old Apr 4, 2008 | 02:47 PM
floppa76's Avatar
Sounds like a bad connection in the wires. If you know any electricians who have or even know what a megger is have them check your harness. It'd be a good idea to look at all your connector plugs as well.
Old Apr 5, 2008 | 12:30 AM
Terrellster's Avatar
I'm voting for a bad TORS switch somewhere on this one. Check the two swithces and see if you can find which one is bad. (or which one has a bad wire.)
qsportgoat has a good idea. Bypass it and see if it runs without the safety stuff.
If it does work, buy a 35 dollar tether type switch to replace TORS.
And of course,, as I always ask,.... keep us informed on what works...
Old Apr 6, 2008 | 05:58 PM
Mlarkin_09's Avatar
Turns out it was the stator after all. Thanks for the help Runs great now
Old Apr 6, 2008 | 08:39 PM
<div class="FTQUOTE"><begin quote>Originally posted by: Mlarkin_09
Turns out it was the stator after all. Thanks for the help Runs great now</end quote></div>
Bad wire to Stator? Internal Short? Or did you just put a new one on and it works fine now?
Curious to know...
Old Apr 7, 2008 | 08:04 AM
qsportgoat's Avatar
wow thanks for the feedback, sorry if i led you in the wrong direction. glad to here its running
Old Apr 13, 2008 | 08:28 PM
Mlarkin_09's Avatar
I just put a new one on and it works great now I think it was the pulser coil
Old Apr 13, 2008 | 11:33 PM
Thanks. pulser col would do it.
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
