Frustrated Timberwolf
Old Apr 20, 2008 | 11:57 PM
SadTimberwolf's Avatar
Default Frustrated Timberwolf
Any help would be greatly appreciated. I have a 92 Timberwolf that has never let me down in 16 years, but last fall I started it up one morning and it idled fine, but died as soon as I pushed the throttle.
I have good compression (wet and dry), good spark, timing is good, I rebuilt the carb (except I feel like that is still the problem, bad kit maybe), i put a new muffler on (the old one was really bad), new air filter, flushed the gas tank, and no change. Please help, I'm out of ideas.
Thanks,
Old Apr 21, 2008 | 08:37 AM
justhanginout's Avatar
sounds to me like you have an air leak some where maybe a crack in your connector boot from carb to motor. or one of your vent lines is clogged.. good luck
Old Apr 21, 2008 | 10:07 PM
brokemybanshee's Avatar
try it without the airfilter on, DONT ride it like that, but start it up and see if theres a diffrence when you hit the throttle, if so it might be a clogged pilot jet. Could be the TORS if they have it on that model, throttle overide BS..
Old Apr 21, 2008 | 11:40 PM
I'm with you on the air leak, I just have not been able to find it. Is there any way to check that boot or do I have to just buy one and try it.
Thanks!
Old Apr 21, 2008 | 11:43 PM
I've tried the air filter, replaced the pilot jet, still no go. I don't believe this antique has the TORS, but I'll check.
Thanks!
Old Apr 22, 2008 | 04:43 PM
take some starting fluid and spray it around the conecting boots ect. if there is a leak you should notice a slight increase in idle.
greg74
Sep 10, 2019 03:03 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Whitelx1
Oct 2, 2015 10:55 PM
toonces
Aug 21, 2015 01:19 PM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
