nned help with my kodiak 450
Old Apr 21, 2008 | 09:33 PM
buggyrider18's Avatar
Default nned help with my kodiak 450
when it smokes its about as much as a cold two stroke would smoke not quite as bad but close.
Old Apr 21, 2008 | 10:50 PM
Traildad's Avatar
Well a two stroke burns what 30 to one or something? In five minutes it won't burn much gas and only 1/30th as much oil. Have you checked to see if it is going elsewhere like the air box or the radiator etc?
Old Apr 22, 2008 | 09:21 AM
pmcc37's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Traildad
Well a two stroke burns what 30 to one or something? In five minutes it won't burn much gas and only 1/30th as much oil. Have you checked to see if it is going elsewhere like the air box or the radiator etc?</end quote></div>
if its not smoking like a frieght trian, then its proabaly somewhere else you may be burning a little n then some going into the radiator, check it and see if its milky... but to be bone dry in 5 mins with no leaks your packing may be absorbilg alot of the fuel.
willie- no offense, just your org. post didnt make much sense. I still don't see it going into the airbox, but i have seen stranger things working on motors....
Old Apr 22, 2008 | 12:26 PM
Williebee's Avatar
pmcc37 no offense taken i do tend to go on about how my 88' Jimmy was smoking and burning oil , and how i was about to sell it for whatever i could get for it ; i was willing to take a big loss on this one !
If it hadn't been for the Sea Foam i would've taken a big loss , so it was a good thing the mechanic who put the timing chain and gear set being to busy to put new seals in the transmission of my Chevy S10 ; i would've sold it for scrap metal if it hadn't been for the Sea Foam !.....
Old Apr 22, 2008 | 08:31 PM
  #15
i havent checked the air box or the radiator. havent heard of the oil going into there? should i just drain the aintifreeze and check for oil or what?
Old Apr 23, 2008 | 09:57 AM
  #16
pmcc37's Avatar
if its in the radiator, just open the cap, if its a milky color, theres your problem, if for some reason its in the air box let me know and take pictures, cuase i wont believe it...lol
if its in the radiator, you have a crack somewhere in your water passage, head gasket(but would still be showing oil-just more n milky) or a cracked head. or jug, either way you'll have to taer it down to find the culpret
Good luck in keep me updated.
Old Apr 23, 2008 | 10:31 PM
  #17
thanks im hopin the wife will give me sum free time to work on it this weekend without bitching lol
Old Apr 24, 2008 | 09:53 AM
  #18
pmcc37's Avatar
good luck
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
