Warrior Tires ?
Old Apr 24, 2008 | 11:49 AM
cfdwarrior03's Avatar
Default Warrior Tires ?
The stock tires on my warrior were 22" tall in the front and 21" tall in the rear. What is the offset for? My tires I ordered came yesterday and I may have made a mistake. The front and the rear are both 22" tall I don't no if this matters but it actually makes the bike look a little funny. Since I went 1" taller in the rear do I need to by 23" tall for the front to have that 1" offset?
Old Apr 24, 2008 | 03:22 PM
embler's Avatar
mine has 22" on it, front and rear and I was told they are the stock ones. what year is your warrior? mine is a 2000. you don't need an offset in tire size. mine rides just fine with them and I just ordered a set of kenda klaws for the rear of mine. 22" tall and 11" wide. if you ride trails a lot, doesn't hurt to have extra ground clearance.
Old Apr 24, 2008 | 04:49 PM
pmcc37's Avatar
22" rear and 21" front is stock, but 22's in front won't hurt you any...
Old Apr 24, 2008 | 09:29 PM
Paulie1959's Avatar
Most put 21"s front and 20"s rear, because of 2 things the smaller tire lowers the center of gravity ( less tippy feeling), 20" on rear need less HP to turn them, the taller tires are only better for mudden
Old Apr 24, 2008 | 10:55 PM
embler's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pmcc37
22" rear and 21" front is stock, but 22's in front won't hurt you any...</end quote></div>
maybe on the older warriors. on mine ('00 model) stock is 22/7/10 in front and 22/10/9 in the rear.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
