2006 wolverine
i have a 2006 wolverine. it will not idle without the choke on and the reverse light flashes any ideas? the dealer i bought it from was no help they refused to tell me anything they just wanted me to take it to them to fix it.
i would charge the battery.....when the reverse light flashes it usually means there is a large drwa on the electrical system.... i get it once and a while if i am winching allot.... usually a canam i might add !
i just cleaned the carb on one of my 06's wolvies cause it was running really rich. and i figured it might be cause i moved to a higher altitude but now it's doing exactly what yours is doing. it will idle fine with the choke all on but when you take the choke off it just dies. i haven't had time to mess with it. when i figure it out i'll let you know
yea the dealer said they had some problems with the jetting or something but would not say anything else to me and i would rather fix it myself then pay them if they wont help me out a little i was a good coustomer to them
dealers are ignorant and stupid i'm deffinately not a fan. you spend 6grand and they don't want to tell you crap. like when i broke my woodruff key. i explained to the dealers what was wrong and they were like you would have to bring it in. eventually after calling enough places i found one that told me exactly what it is and even offered to pull the stator for me if i brought it in. so now i buy everything from them.
Is your air filter clogged? Have you guys jetted for altitude or was your bike jetted in the cold weather? A bike that is set up in winter and runs fine might not in spring/summer temps. What is the altitude where you are? It seems that all bikes come from the factory set up for sea level and will run rich over 2000ft. I live at 5000+ and changing the jetting made a huge difference.
lol toddmh i tell you what that chair just missed your head. [img]i/expressions/face-icon-small-tongue.gif[/img]
I havent had a problem with my wolvy like that yet. I am gonna pull out the manual and dig through it tonight or tomorrow for this post and another one like it.. Hopefully ill be able to help you guys out a little.
As far as the light flashing, usually mine only does it when you rev up higher while in park or neutral, its a warning to tell you not to shift into gear as you could damage something. So it could be an electrical problem causing this instead of the carb. Possibly a rev limiter acting up.
