Battle of the wolvies (old against new)
Old May 2, 2008 | 09:14 AM
justhanginout's Avatar
Default Battle of the wolvies (old against new)
Type 421cc liquid-cooled 4-stroke; SOHC, 2 valves
Bore x Stroke 84.5mm x 75.0mm
Compression Ratio 10:1
Carburetion Mikuni 33mm BSR
Ignition DC - CDI
Starting System Electric
Transmission Yamaha Ultramatic® V-Belt / F,N,R
Engine Braking Front & Rear Wheel
Drive Train Yamaha On-Command® pushbutton 2WD, 4WD ; Shaft
Chassis
Suspension/Front Independent double wishbone; 5-way preload-adjustable shocks, 6.3-in travel
Suspension/Rear Swingarm; 5-way preload-adjustable, 7.1-in travel
Brakes/Front Dual hydraulic disc
Brakes/Rear Hydraulic Disc
Tires/Front AT23 x 8-12 Radial
Tires/Rear AT23 x 10-12 Radial
Dimensions
L x W x H 77.9 x 41.9 x 43.1 in
Seat Height 33.1 in
Wheelbase 48.5 in
Turning Radius 118"
Ground Clearance 8.7 in
Fuel Capacity 3.8 gal
Dry Weight 516 lb
Rack Capacity N/A
Towing Capacity 1,102 lb with optional hitch
ENGINE
Type 4-stroke single, air/oil cooler, SOHC
Displacement 348cc
Bore x Stroke 83mm x 64.5mm
Compression Ratio 9.2:1
Carburetion Mikuni 34mm
Transmission Five-speed automatic clutch w/ reverse
Drive Train 4WD, shaft
Starting Electric w/ auxiliary pull
CHASSIS
Front Suspension Independent double wishbone, 7.1 inches of travel w/ five-way preload adjustment
Rear Suspension Swingarm, 7.1 inches of travel w/ 5-way preload adjustment
Front Brake Dual hydraulic disc
Rear Brake Hydraulic disc
Front Tire AT23x8-12
Rear Tire AT23x10-10
DIMENSIONS
Dry Weight 477 lbs.
Rear Rack Capacity 132 lbs.
Towing Capacity 728 lbs.
Fuel Capacity 3.4 gallons
Length x Width x Height 73.6 inches x 42.3 inches x 45.3 inches
Wheelbase 48.4 inches
Ground Clearance 8.7 inches
Seat Height 31.1 inches
Colors Team Yamaha blue/white, black
*YOU DECIDE THE VICTOR*
Old May 2, 2008 | 10:20 AM
pmcc37's Avatar
Just as long as you keep everything above water, don't sink it, "just hangin" your not going to have any belt or other problems..... Which has been brought up in another thread. They have more power, come stock with 4x4 select, but dont have locking differiential up front, that would help
As far as the old woly's there kinda pinchy, there slower than a big bear, smaller tires, ect, ect ect. Same bike with smaller tires. Stock they don't make much sense, but you put the 424 select and redo the engine and you got something, otherwise you got a big bear with smaller tires and a diffrent name.....
Old May 2, 2008 | 10:26 AM
pmcc37's Avatar
just hangin
p.s. this one looks better.. lmfao
Old May 2, 2008 | 10:40 AM
yeah i really like that color. i might take the one of mine that was stolen and redo the plastic instead of painting it. as far as the belt when i first got mine i was an idiot and didn't know about the drain plug well after taking it out 3 or 4 times with out draining it started slipping. and maybe it's just me but i've always thought mud was dirt and WATER.
i kind of like the design for the older model better maybe it's just me but it looks differnt and i like that and like you said there is so much more stuff you can do to the older ones but thats just cause they've been out longer.
i wonder if you could put the 450 in the older model.
Old May 2, 2008 | 10:46 AM
pmcc37's Avatar
i think you could put a 450 in a older model, but not the one out of the new ones... now a kodiak motor probably..... shift driven, i dont thnk theres enough room for the auto... but then your into all kinds off issues, plus you can build the hell out of the older ones and it's not going to be as fast as the new ones
Old May 2, 2008 | 11:25 AM
Eimajz's Avatar
One thing for sure is the floor boards on the new 450 is really a **** poor design. I broke mine all to he%% before I could get some skid plates built.
Old May 2, 2008 | 11:30 AM
yeah i'm not a fan of the foot boards. mine are broke on one of mine and it's not that much to fix them 15 bucks it's jut the principal. i think the dealers need to come out with an ATV thats already all moded out.
Old May 2, 2008 | 11:55 AM
pmcc37's Avatar
yeah i agree to both comments, but that would put the aftermarket business out of business, there all in cahoutes*sp
Old May 2, 2008 | 12:07 PM
pmcc37's Avatar
does anyone know if they make a regular rear rack for the new wolys?
Old May 2, 2008 | 12:38 PM
idk
