small blaster problem
Old May 16, 2008 | 01:48 AM
Jabes's Avatar
Default small blaster problem
for a stock blaster motor if your under 100 psi its time to rebuild
Old May 16, 2008 | 11:34 AM
ATV_MAN's Avatar
I would check compression like they say and also check your carb, you could have dirt clogging your jets.
Old May 16, 2008 | 02:14 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
I've read that blasters had problems with the auto lube. Plastic gears getting stripped causing insufficient mixing of oil. That's why you see alot of them with block off's and people pre-mixing. Don't know how old you blaster is or if it's a problem but, something to look at.
Old May 16, 2008 | 03:54 PM
xxxalpinexxx80's Avatar
could the plug be fouled and how hard or how do u clean the carb
Old May 16, 2008 | 08:45 PM
  #15
mdebuck's Avatar
i highly doubt its the plug. so get off that subject. take off the carb and dip it into some carb cleaner and that should just about do it.
Old May 17, 2008 | 04:21 PM
  #16
1 more question, could it need a new fuel filter?
Old May 17, 2008 | 10:38 PM
  #17
im pretty sure i found the problem, i think it was the carb ring that as loose
Old May 17, 2008 | 11:41 PM
  #18
mdebuck's Avatar
well i'd stil check your compression just for ***** and grins
Frisky2050
Apr 9, 2020 11:19 AM
Captjay
Jul 23, 2015 12:33 PM
joeyupton
Jul 14, 2015 11:51 AM
steveo612
Jul 11, 2015 08:35 AM
black_thunder
Jul 9, 2015 05:58 PM
