painting plastics
OK guys 25 years of automotive painting here. First it must be sanded (plastics) with very fine grit paper. If you start getting fuzzies the paper is to gritty. I suggest 600 then 1200 wet for sanding plastics.You don't have to take all the paint off just feather out the scatches. Then you must and I mean must use a plastic adhesion promoter before painting.It sprays clear but it makes sure the new paint will stick and will not crack if bent.
#15
I went to an auto painting seminar last week for work, and they displayed new gloss primers with flex additives that can be rolled on. I was skeptical until they painted a beach ball and the paint flowed smooth with no lines and did not crack as we bounced it around the garage.
It dries slow enough to blend into a seamless finish. Obviously you would have to fine sand if you were going to cover it with an Auto Urethane. I have had reasonable success with fusion and a plastic paint prep, but still had some chips and flakes. I believe it was a PPG product demonstrated, but there are others. Check it out at an auto paint store. It will not be as cheap as a can of fusion though!
I may try it soon out of boredom and the willingness to experiment. If so, I will post pictures.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
