01 warrior no start
Old May 30, 2008 | 01:08 AM
manther's Avatar
Default 01 warrior no start
Accidentally left the key on and drained the battery. Put it on the trickle charge, came back several hours later, and it started. Left the trickle charger on there all night. Came in the next mourning and the battery was fully charged, but the starter does nothing when I hit the button. Head light comes on full power. Neutral light is nice and bright... Any ideas?
Old May 30, 2008 | 08:50 AM
WV250ex's Avatar
My warrior has the same problem, you should check inside the starter and make sure the seal isnt bad because my starter was full of oil from a bad seal....
Old May 30, 2008 | 10:47 AM
tricksh@t's Avatar
also check your brushes in the starter its common for them to wear out
Old May 30, 2008 | 11:33 AM
pmcc37's Avatar
alot of times on the warrior once you drian the battery they will work the headlights, but won't turn the starter, even though it show full charge the are pretty much junk...
Old May 30, 2008 | 02:56 PM
manther's Avatar
In these cases pmcc37, what was the solution?
Old May 30, 2008 | 03:06 PM
91Warrior357's Avatar
yea, new battery, how old was your previous battery?
Old May 30, 2008 | 03:26 PM
manther's Avatar
I think about a year old. How could I test that the battery is the problem?
Old May 31, 2008 | 11:10 PM
Octane2079's Avatar
Go to an auto parts store and have it load tested.
Old Jun 2, 2008 | 11:18 AM
manther's Avatar
Well, I think I found the problem. The battery was strong enough to power the head lights but not powerful enough to trip the relay. Maunally tripped the relay with a screwdriver, and the second the starter motor tried to turn over, the lights went dim. Put some jumper cables on the battery and the atv fired right up. So like someone I think already said, I'll probably be buying a new battery, because I jump started it and then drove it around for a good half hour trying to get a charge back into it. Turned it off, then back on, off then back on. But, when I turned it off and walked away fro an hour, and came back, it was dead again. Thanks for the help everyone.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
