make a raptor go faster
Old Jun 18, 2008 | 11:49 PM
Mikeu12's Avatar
Default make a raptor go faster
if i wanted 2 drag my raptor to go like 120 mph what can i do expect for changing the gear ratio?
Old Jun 19, 2008 | 12:16 AM
91Warrior357's Avatar
big **** front sprocket, small back, lowered, rev box, p3 controller
Old Jun 19, 2008 | 12:18 AM
Raptor450's Avatar
Seriously doubt you could ever get your Raptor to go 120 mph. 90 mph might be more realistic with the Raptor engine, but that's still pushing it. You would need several thousand dollars and: big bore/stroker high compression kit, cam, port and polish, valve job, possibly nitrous, lighten it up as much as possible, lightened flywheel, lock-up clutch, etc..........
Old Jun 19, 2008 | 12:40 AM
bigned1904's Avatar
it will hit 90 n/p with like a 16 or 17 tooth. 120 i dont know im trying to find a gearing chart. i would think need to be a 20 tooth min. as far as mods to get going that fast not sure what kind of hp you would need. depends how long you got to get going. but it can be done no problem. the best raptor 700 builders are tim barker, rocket factory, kenz cycle and racer edge. they can make you as much hp as you want pretty much. kenz and rocket factory have no problem building you a 100+hp raptor if you got the $. and racers edge can get you 75-80hp for like 3k on a stock bore. tim barker just developed a new cnc machined p&p that has crazy good flow bench numbers but has not built a ton of raptors yeat but is work is top notch.
Old Jun 19, 2008 | 12:53 AM
Mikeu12's Avatar
that sounds awesome but yeah i still want to trail ride and all so i dont wanna change the sprockets and **** if it takes me a while to go faster
Old Jun 19, 2008 | 12:56 AM
bigned1904's Avatar
you will never hit over 80 with stock sprokets.
Old Jun 19, 2008 | 12:59 AM
Mikeu12's Avatar
yeah i know but ill need a new chain if i wanna change the sprockets rite?
Old Jun 19, 2008 | 01:03 AM
bigned1904's Avatar
i think if do if you go over 16. i know for a fact you can do 15t which people love for dirt. they say way less wheel spin but the power down low is still there.
Old Jun 21, 2008 | 01:51 AM
1989250moto4's Avatar
get a turbo for it and gear it how ever you want to, if that dont work put a 600cc street bike engine in it
Old Jun 22, 2008 | 11:18 AM
gus700's Avatar
There is an easy formula for gearing:
____<u>ENGINE RPM</u>____ x Rolling radius of rear tires x .0059
Over all reduction
Random Example: if you had
2:1 primary reduction
1.23:1 fifth gear
<u> 2.75:1 final drive </u>
6.765:1 overall
9000rpm/6.765 x 9.5"(approx. rolling radius of 20" tire) x .0059 = 74.56 mph
9000rpm/6.765 x 10.5(22" tire) x .0059 = 82.42mph
