how to change a clutch in 03 blaster
ok well i put the clutch in it and not sure if i did it right. i did put the discs in right but i dont kno if they were the right way. i put the fiber in first and then metal but on the metal there is a little hump on the outside is there a special way the metal plates go according to those bumps? also there was a metal ring with the clutches and not sure what it is. i took it out with the old clutches and 1 didnt come with the new so i put it back with the new ones where it was in the first place. what is that? also if anybody has the torque specs for the spring screws that would be appreciated. thanks i need help lol.
I don't know what the torque specs are for the spring screws, I think the ring you are talking about is the wavey tension spring and yes that should be in there. Also make sure that the little ball is in the middle hole where the little rod goes in. You may have to play with the internal setting to get it right at first but after that you should be able to get enough at your handle. As far as the torque specs just give your yami dealer a call and they can tell you.
http://youtube.com/watch?v=br63PLcq3sU
that should about sum the job up for you right there. watch that and learn young grasshopper.
thats great info but i did every thing he did and when i put the pressure plate on, and the case back on the clutch lever on the handlebars was very loose like there wasnt a clutch installed. does it jus need adjusted somewhere? i kno i put the plates in right. could the tourque be an issue because i jus hand tightened the spring screws because i didnt have a torque wrench? thanks everyone
