Toomy needles with FMF pipes
The Toomey Needle kit, I beleive, is the same as the one DynoJet sells. Non the less, it is well worth the $$. The needle makes for a great transition from Part to Full throttle, and a little more power all around. I put the Toomey needle in my brothers Banshee W/FMF Gold's and it made a world of difference. I was having a hard time finding the right combo of jets and needle, before trying the Toomey Kit. It runs great now.
You should run 30 pilots and 290's on the main. This jetting depends on area you ride and your airfilter choice. My choice was running the Toomey 2 into 1 foam filter with the Uni FOAM outerwear.
Good Luck.
Good Luck.
Thanks for the input "Itsshemp". I had the head shaved and rechambered, the timing is advanced with boyseen reeds and K@N filter. I'm running a 350 main and never changed out the piolet. Changing the piolet jet make a big differnce?
4Ever, The pilot jet works in conjunction with the air screw from idle to off idle to 1/8 throttle. You might not find any major improvment over the entire power band, by increasing the pilot jet, but it will improve the area mentioned.
What you want is a smooth transition from idle to full throttle, without a lean condition.
Your jetting seems alittle "fat" to me, but I dont know what kind of air conditions you normally ride. I ride at Glamis, and 320's seem to run in the safe zone for me. Try making a jetting pass, and check the plug. Without an EGT gauge, its really the only way to know if your jetting is ok. Better off a little "rich" than a little "lean".
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
