rookie carb questions...
ScramDaddy and No2Stroke are both right, a Black plug does mean rich, but No2Stroke is also right, it doesn't mean your main jet is too rich, the only way to do a plug check is full throttle for at least 30 seconds. Just because it is black, doesnt mean you are rich everywhere, just means you were rich somewhere. You can only use plug color for main jet adjustments, and for that you have to run full throttle, then pull the clutch and kill the engine, then look at the plug. Most likely, you are lean on the top and rich on the bottom.
Don't listen to these Yamaha fat cats they think they know everything.
I know your right
1998 Honda Recon, Sur Tracks on ITP aluminum, UNI air filter
www.geocities.com/hondapride_98
I know your right
I think you have gotten a nose bleed from sitting on that extra tall,poor excuse of a sport quad Polaris.Are you telling me that a pulg will not get black from sitting at idle? Or has that all of that 2-stroke smoke polluted your thinking as well. And, uh, yeah, at least my quad aint red, or something.
#15
#17
#18
Do yourself a favor, and take a look at this website. It is a good source for CV carb tuning, which is what the Raptor has, twin 33mm BSR.
http://www.factorypro.com/tech/carbtun.html
Don't listen to limpdaddy, he is clueless.
Not to mention a whinning know-it-all jack**&$#
#20
BlueLeader,
I am unsure why nobody has mentioned this to you. You are talking about a WB E-Series. Right?
All the people I know with these, no one has had to re-jet.
YOUR SILENCER IS ADJUSTABLE!!!!!
More discs and less discs will change your being lean and or rich. TRY IT. You should be able to dial it in, without touching your carbs.
Unless you have modified the airbox!
