08 Big Bear rear differential leak
Old Oct 27, 2008 | 07:42 PM
SwampSnyper's Avatar
Default 08 Big Bear rear differential leak
Noticed a lil oil around the seal. None on the ground. Should I be concerned?
Old Oct 27, 2008 | 10:15 PM
cherokee99's Avatar
differential leak was a big problem on the 07's. last i knew yamaha hadn't found a sloution other than replaceing seal after seal [img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 28, 2008 | 11:14 AM
willieb76's Avatar
are you taking about a little seepage or a big leak? if it is just a little seepage collecting dust just wipe it down once and a while and fugitaboutit
Old Oct 28, 2008 | 01:05 PM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: willieb76
are you taking about a little seepage or a big leak? if it is just a little seepage collecting dust just wipe it down once and a while and fugitaboutit</end quote></div>
True.. and also.. when you wash your atv.. don't point the hose directly at the seal..... been there done that!
Old Oct 28, 2008 | 01:10 PM
Just a lil seapage. Just wondering if it was normal or the begining of a problem.
Old Oct 28, 2008 | 02:21 PM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: SwampSnyper
Just a lil seapage. Just wondering if it was normal or the begining of a problem.</end quote></div>
NOT Normal --- oil leaking from your Quad is not normal... I am having problems with my '07 Grizzly 450... leaking oil... 1st time the replace the rear output seal, 2nd time they replaced all the bearings on that shaft and the seals... 3rd, yet to be determined! Personally I am not happy that a 2 year old quad... with 1100 miles is already leaking oil... I am SO HAPPY I have a 2 year warranty.. which is good until Dec 2009.
Old Oct 28, 2008 | 09:11 PM
cherokee99's Avatar
is that all yamaha yamaha can do, just keep replaceing the deals and bearings? have they resolved the issues on the 08, 09 models at all?
Old Oct 30, 2008 | 10:29 AM
trapperdirk's Avatar
I have a 2008 Big Bear with 1900 klicks on it and it doesn't leak a drop anywhere . Leaks are never a good thing and if oil is getting out then crap can also go in .
TD
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Peter_
Jul 18, 2015 07:06 AM
