warrior
Old Nov 10, 2008 | 01:08 AM
Andrew's Avatar
Default warrior
how to disable the rev limiter on a 04 warrior any help will be great
Old Nov 10, 2008 | 09:37 AM
beefy46172's Avatar
Loves To Ride!
Default warrior
Dynatek CDI box.
Old Nov 10, 2008 | 01:00 PM
Evasiveone's Avatar
Default warrior
The Warrior does not have a high revving engine to begin with. It will begin floating the stock valves rather early so raising the RPM's will gain you nothing.
Old Nov 11, 2008 | 12:11 AM
Andrew's Avatar
Default warrior
IM not trying to gain nothing. do i need to buy a Dynatek CDI box? cant i just disable it some how?
Old Nov 11, 2008 | 12:15 AM
Andrew's Avatar
Default warrior
it just dont run and ever thing is right but the rev limiter wires were cut try hooking it but reved high and pop and die
Old Nov 11, 2008 | 08:40 AM
beefy46172's Avatar
Loves To Ride!
Default warrior
The CDI box is the rev limiter- you can't just cut some wires and get around it.
Old Nov 11, 2008 | 03:19 PM
Evasiveone's Avatar
Default warrior
Those wires that are cut are something else. Like Beefy46172 said the rev limiter is built into the CDI on almost all quads. Cut any wire coming out of the CDI on the Warrior and you will have a no run condition.
Where are these wires at that are cut on your machine?
Old Nov 12, 2008 | 02:55 PM
Andrew's Avatar
Default warrior
the wires were at the clutch lever/barking brake but I hear that is were it was at i put them together but it rev high . but what wires do i need to cut and can i disengage it?
Andrew's Avatar
Default warrior
Old Nov 12, 2008 | 06:02 PM
warriorslayers's Avatar
Default warrior
It sounds to me like it's the stupidest thing that could be on a quad.... I think they wen't to the parking brake like you said... but the brake has a engine speed limiter hope that helps...... does it back fire alot... want to stall when you hit the gas...
