Getting a 2003 Warrior and have some questions
Old Dec 18, 2008 | 05:41 PM
  #41
djm1k0's Avatar
Default Getting a 2003 Warrior and have some questions
<div class="FTQUOTE"><begin quote>Originally posted by: beefy46172
Yes, and top off as necessary while bleeding because if you run it too low you will have to start all over again.</end quote></div>
I did the brake bleed and it's all good. Brake works fine. However;
I also changed the tie rod and it's good but am unsure whether i did it right. how do I properly adjust the the tie rods so that the camber is correct on the front wheels. It appears that the front wheels are leaning out a little bit on the top if you are looking at the machine from the front. Is there a proper way to make these adjustments ?
again your help is greatly appreciated so any guidance that you can provide would be great !!
Old Dec 18, 2008 | 09:53 PM
  #42
beefy46172's Avatar
Loves To Ride!
I replied to your other thread about that, check it out
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Kyle5050
Dec 13, 2019 04:25 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 6, 2015 05:29 PM
