Yamaha Warrior bogging down
Old Sep 8, 2011 | 11:57 AM
bryan350's Avatar
what coler are they
Old May 17, 2017 | 12:24 PM
dixond's Avatar
Default 94 yamaha warrior 350
Originally Posted by bryan350
where is the parking brake
my warrior starts idles but bogs down when i give it gas
Old Dec 29, 2024 | 01:42 AM
Noah1354355's Avatar
Default My 2001 or 2003 warrior 350
Originally Posted by BaronAlm
I have a 1998 yamaha warrior 350. About halfway through each gear it bogs down and acts like its trying to backfire. I can shift into a higher gear and it will run but then starts to bog down halfway through that gear! Any help?!?!?!?!?!?
my warrior bog out half throttle in 3rd 4th 5th and 6th but I just replaced stator carb and spark plug what would it be the jetting in my carb ?
Old Dec 29, 2024 | 04:09 AM
I have no experience of the Warrior, but a misfire caused by a faulty rev limiter is different to carb problems, you can hear when a bike hits the limiter as it stutters, carbs that are wrong cause an engine to run out of power. If you still can't work out which it is, follow the suggestions above, start from replace the plug (your new plug may not be a good one) and work down. A compression check could also be useful, as low compression causes an engine to run out of power too, though it also makes them bad to start as a rule. If you end up thinking it is still a carb problem, fit the jets from the old carb, or clean out and re-fit the old one.
Old Dec 29, 2024 | 05:02 AM
  #15
papa hogg scoot's Avatar
Loved
Community Favorite
Also checking charging system under or over charging can also cause this issue
Ryan112172
Jan 24, 2007 08:51 PM
Swails
Dec 1, 2006 10:55 PM
poppo
Jul 1, 2003 09:59 PM
