ATTN TERRAPRO OWNERS
Old 01-04-2009, 02:48 PM
DML's Avatar
DML
DML is offline
Default ATTN TERRAPRO OWNERS
I have a Terrapro that I'm having a problem with the "high" range. When I try to put it in high range the engine stalls. I know it is a safe gaurd for when mower is attached to keep the high range from working. But I have the mower off. The rear differential has to locked in order for it to work in high range. There is a switch some where and this may be bad but I can't find it. Has anyone has this problem??? And where is that switch?? Thanks
Old 07-24-2011, 11:14 AM
dbaker13's Avatar
Older post I know but am having the same issue...have checked all fail safes and the are functioning correctly...relays also ok...anyone know where all the fail safe switches are...I may be missing 1.
Thanks for any input.
Old 08-28-2011, 08:06 AM
dbaker13's Avatar
OK, resolved...mechanic friend of mine found a bad switch directly off the transmission. Part is discontinued. He had to bypass the safety...which means that will go into high range with PTO engaged but all other safety features are intact.
Hope this helps.
Old 06-22-2012, 06:51 PM
Rayroc's Avatar
Default PTO Safety Switch
I'm having a similar problem with the engine stalling on low and high gears when the pto is hooked up. I think it's the safety switch you mention that's causing it. You mention it's directly off the transmission.. What does it look like and how did you bypass it? do you have a photo or sketch of what you did? Many thanks for a response.
Joe454
11-20-2020 01:19 PM
Customer Service #1
05-15-2020 08:46 AM
95wolv
03-09-2020 03:25 AM
wendal
10-31-2017 03:31 AM
Ahtatu
09-28-2015 12:14 PM
Quick Reply: ATTN TERRAPRO OWNERS
