rebuild help!
Old Jan 8, 2009 | 01:15 AM
wmtitan024's Avatar
Default rebuild help!
i have a 99 blaster bought it last year. i want to put new piston in it but i dont kno how to measure the piston. i kno the guy before me bored it but i dont kno the oversize. how do u measure it then calculate the oversize to purchase the piston. i thought u use a micrometer but how would that work
Old Jan 8, 2009 | 01:34 AM
cherokee99's Avatar
you take a micrometer, move the the measuring points so the flat sides face outward, and measure the diameter of the cylinder. best to measure the top and bottom of the cylinder. since the piston never really touches the bottom of the cylinder that will give the most accurate measurement of what it USE to be. compare it the the measure from the top of the cylinder, if the t measurements are off by a few millimeters, or good% of an inch, then you really need to rebore the cylinder.
but anyway the diameter of the cylinder is what you want. then compare it to diameter of stock cylinder: 57mm stock bore i think
Old Jan 8, 2009 | 01:39 AM
wmtitan024's Avatar
thanks cherokee u help me twice lol i knew a micrometer came in somewhere, i did a rebuild on my honda and i new it was stock everything so i didnt measure, but thanks again
Old Jan 9, 2009 | 01:11 AM
Doctorturbo's Avatar
GOT BOOST!
I just look at the number stamped on the piston top. You can stick a feeler gauge between the piston and the bore to see what oversize to get.
Piston + feeler gauge + .010 to clean up the bore...........order that piston.
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
